jessesigmon
Settings-about phone-system updates- zte warp software update on sdcsrd? Whats this for? Tells me to insert update package to image directory on sd cardand press okay. Any thoughtz or comments? Thanks in advance
The other day as I was updating to b08 I copied the zip file from the update after it downloaded. I would bet if I renamed it to update.zip I could put it on my sd card and update my phone with it. But I didnt try it.I was curious, so I pushed the "Update ZTE Software from sd card" the only thing that it did was rebooted my phone and some options came up after the reboot telling me to either just reboot or use the file on the sd card which I did not have. so I think that this is for you to update you phone from your sd card if you have downloaded the updated to your card. I think that if you have found some updates from the ZTE place and you have downloaded a few files this may give you the choice to pick which update you want if you have any downloaded updates to begin with. I hope this helps in some way. I am not an expert on these kind of matters. I just like to try and help people understand what I can. Good luck
No it saved it to my computer somewhere in {C:\Program Files\Handset software update tool\Handset software update tool} and I grabbed it before it was done updating and saved it. Its called N860V1.0.0B16.zipThat very well may be the case, I am going to updat that very same file myself here in a bit as soon as I get done backing up all my apps, then I will give it a go, I'll let ya know if it saves it to the card or not and if it does if I can update it from the card.
