Root [Boost Mobile] which ROM should I load for a freind
hroark13
Android Expert
Recognized Developer
Hi All
I have not had a chance to test the various ROMs for the Warp because I always have CM9 or CM7 on it and I do not use my Warp as my active phone, I am still using my Prevail
I have a friend who has a Warp, and she is having problems with sound settings not staying and other issue, so I am going to load a custom ROM for her.
I was wondering if you guys can advise which ROM I should use for her, the most important thing is stability, and everything working properly.
MINE!!! Nah jkjk... Mine is still technically in the works... so far its not buggy though... maybe Simple Rom or n00b rom...
Sent from my N860 using Tapatalk 2 Beta-5
Mine is stable it requires a selection of kernels to find the right one but once you find it its super stable and super fast all testers and such love it
Edit: once a good kernel is in place everything works like a charm :D if not then the only thing wrong will be setting not sticking
I suggest Unitology, it's a very very stable rom. You may have to flash a different kernel but that takes like 2 minutes, once you get a kernel that works 100% it's super smooth. The reason you may have to try a different kernel, is it seems that different phones react differently to the different kernels. Not sure why, but once you find the one that fits your phone perfectly...you won't have ANY problems with unitology. By far the smoothest I've ran thus far.
Sic freak thank you for explaining that
Don't you dare think about using my rom lol! :p Everything works on my rom so long as you use the non-OC kernel posted in the OP, there are still a few bugs i'm working on for the next release.
if you don't want to get too extreme, on the third post of the n00b ROM thread I have a stock deodexed b08c, might be a good place to start. Also links there to add crt/power menu as well if you go with deodexed stock.
Most of the ROMs on here are damn good, but my vote has to go to the nOOb ROM. It is simple, stable and still has Voice Dialer. It is also easily modified. Enjoy!
