There is no alternative radio for the warp (s-off). and changing the radio wouldn't do anything for wifi. I have never had a faster connection with wifi vs usb tethering. Where did you hear wifi has a wider band width for data connection?
That would currently defy the laws of physics considering that when transmitting a signal via airwaves more data/power/signal is lost due to the lack of efficiency of receiving (it just "floats" away in laymen terms without a direct path). Currently the best transmitter is a simple copper wire.
My best results have been on usb tether, Phone is plugged in directly, when the screen sleeps your using less processing power, ahd charging the phone at the same time.
I agree, usb tether has worked so much better, less lag, a lot faster!!!
I got that info from a tech guy that flashes phones for a living. What you said is basically what I thought but he disagreed and said something about a direct connection is a confined/constricted bandwidth and wifi is not. I don't know, thats why I ask so I appreciate your input. With that said, it must be a hardware issue, such as a weak signal transmitter for the wifi.
I hear you. The reason why it's faster is simply because it's confined/restricted. Imagine a spray of water from a shower or sprinkler. You are thirsty. What is the best way to get water in your mouth? To restrict or confine the particles in one consolidated space and directly to your mouth from a hose or glass target than a non confined spray or wave of particles going ask over the place in an inefficient manner.
Your tech guy is a horrible armchair physicist lol. You better hope he doesn't get any silly ideas of his own when coming with your phone.
