Root [Boost Mobile] Zte Warp no notification bar, no signal
i tried the method alsaces suggested but no luck i my phone wont ring or vibrate when i get a call the caller id screen doesnt come up i have to go to my call logs to see if i had a call same with the text messaging, i have no notification bar so i cant mount my phone to the computer i cant see if i have a signal or anything.......IN DESPERATE NEED OF HELP..........
I've had this problem before. It was with shin's ROM. Bad flash. Factory reset, Fix, clear, clear and install. But since you said that wasn't the case it could probably be a kernel issue. Have you tried any other ROM?
