Root [Boost Mobile] zte warp problem with ROM toolbox
so i rooted my zte warp a little less then a week ago and i used ROM toolbox to do some tweaks to the battery and what not. the thing is i want it to go away and it wont. i even set did a factory reset and it didnt go away. i dont know what to do now. i didnt even do anything to save my stock them. please help -_- ill unroot it if i have to just want the damn thing to go away. :confused:
Restore a nandroid backup. Rom tool box does not support the Warp. You can brick ur phone. Dont use it.
Sent from my N860 using Tapatalk 2 Beta-5
so i rooted my zte warp a little less then a week ago and i used ROM toolbox to do some tweaks to the battery and what not. the thing is i want it to go away and it wont. i even set did a factory reset and it didnt go away. i dont know what to do now. i didnt even do anything to save my stock them. please help -_- ill unroot it if i have to just want the damn thing are you talking about the cpu sliders? Set it back and check the box at bottom that says apply on boot,if not cpu sliders then what exacly?
Never do anything to your phone until you make a backup with cwm,once u get it back to norm. Make back up,
