transitoyspace
Member
Yup...check online for instock then CALL...the store i went to only got 2 to sell. They dont even have one for display lol.hey radioshack has the phone already?
First and biggest reason to root...Save money for Mobile Hotspot.
Others are removing bloatware..which saves rom space and have unwanted apps not running in the background. Also there are lots of Root only apps i use.
I want some things to tinker with...like battery percentage..statusbar transparency lockscreen customization. Those things i want. Everything else is perfectly fine for me.
So if you like the phone, thats great. But I and it seems others aswell want to have root/bootloader unlocked to do as we please.
I totally agree with you on bricking it. But I have access to this phone and its not a main phone. So ive been trying to root. Tomorrow ill post my progress and see if anyone has some success.
Its android...i want it my way.![]()
Cheers
What happens when you try to set it up.
I love this friggin phone!
I just got the HTC EVO design as well, and I'm coming from the prevail. I just went online to the Boost website and got the ESN number and used it to upgrade the handset. Beware thou this phone also has a place for a SIM Card and has the IMEI number used to activate it on the iDEN network. Do not use the IMEI only the ESN. After that it said my plan was incompatible and I selected the unlimited plan, $55 unlimited for the EVO design, but since I was down to $40 then I went up to $45 unlimited. It did not change my due date or anything and on the price plan it was "$45 Unlimited W/Shrinkage" so I clicked on that and activated my phone. I already checked calling, voicemail, messaging, and data, and they all seem to be working perfectly fine even 4g.
what kind of speeds are u getting on 4g?? im getting around 3mbs and 200kps upload i live by the beach in los angeles.
Are you sure it's iden? It should be a ruim sim port, that allows you to switch between cdma and gsm depending on what the card is. Check out a full description on wikipedia
Ah ha!!No i was not asked to pay a extra $10 for hotspot but you will be required to change plans from the $55 android unlimited to the 4g android $55 unlimited ( basically no change ) and you will not lose your shrinkage so if you pay $40 now you will still pay only $40 again for the new plan/phone. ( or $50 like you said if you opt for the hotspot addon )
The problem i had is my payments go thru on the 2nd of the mnth so by the time i got mine activated ( on the 5th ) i had allready been 3 days into the new month and it double charged me again for the new phone so within a couple days cost me not 55 but 110 dollars by the time i got it activated. So i called them and they reemburst me that previous month minus 3 days to my account so i'm happy.
So i recommend either waiting till your mnthly due date is about up before activating the new one or expect to go thru the same issue i did and having to talk to customer support to get reemburstment.
Currently you cannot activate the evo thru normal means of doing it via the website because it will say your phone isn't compatible with your current plan after entering the new meid # you will have to call and talk to customer help to get it done because on the site their is no 4g unlimited plan to select yet lol. ( at least it wasn't on 6/3/12 i dunno if they updated site yet or not. )
But i dunno why so many people complain about the boost support i had to deal with them twice to finally get everything working but it was pretty painless and they were very polite and quick to get it resolved for me.
Now as for the phone i love it!! So far it has exceeded my expectations in every way i just got back from RS again today because i had them put a zagg screen on it and hard case before i dared go anywhere with it other then mess with it at home for fear of scratching it lol
yeah .... ummm... all the plans are going to have the cap (4g, 3g, blackberry)... :deal: read the plan discriptions on boost.com and they all display it in nice readable tiny letters :hmmmm: ... the question is will they enforce it and can we get around it.Ah ha!!
There is a difference in the plans... when you switch to the 4g, you are essentially going to to be throttled (or cut off) once you use 2.5gb of data for the month. This is the way the system can keep track, and why they make you switch.
