DISCLAIMER: By using this rom, you agree that you are the only one responsible for anything good or bad that may occur. Use at your own risk.
For Boost Mobile Moto E 2015 LTE XT1526 only.
Stock 5.0.2 Unmodified ROM
surnia_stock_5.0.2.zip
NOTE1: The unmodified ROM is not rooted. To root, flash SuperSU after the ROM
NOTE2: Your device must have a custom recovery such as TWRP to flash ROMs.
NOTE3: These zips are unsigned so you may need to disable signature verification in TWRP before flashing.
Flash in TWRP as follows:
surnia_stock_recovery.img - Stock recovery for the Boost Moto E 2015 LTE
surnia_permissive_kernel - Stock kernel, init.d support, included permissive init.d script
Soak test ROMs [Lollipop 5.1]
Soak test ROMs [Lollipop 5.1] Part 2
- Download ROM
- Put the ROM.zip on your sdcard if not already
- Reboot to TWRP Recovery
- MAKE A BACKUP!!!!!!!!!!
- Wipe data/Factoy reset
- Install ROM from sdcard
- Reboot
- Enjoy!
- Go to Mounts in TWRP recovery
- Uncheck system
- Flash rom again
