Long story short. I was on...
5.0.2 Build Number LXI22.50-14.6 24
I needed to be on...
5.0.2 Build Number LXI22.50-14.8 30
To download that, it's below link along with others (Note: The 5.1 located there is not Boost, I could not get data or voice)...
http://motofirmware.center/files/category/51-moto-e-4g-2nd-generation/
It should be - SURNIA_BOOST_5.0.2_LXI22.50-14.8_cid9_subsidy-DEFAULT_CFC.xml.zip
After this, the original OTA worked and presently I'm on...
5.1 Build Number LPI23.29-18S.1
Dig IT!
But, the voice mail app updated after a wipe and is now constantly trying to send some stupid activation for the dumba** avatars nobody uses. It's the only thing I have seen with issues so far. Voice mails do come in. There was some sprint error that flashed up real quick, I don't know what it was though.
INSERT NO RESPONSIBILITY DISCLAIMER.
Here is the fastboot script so it's a sure thing, NOOB WARNING: you will lose internal SD data and all apps etc.. Backup!
fastboot oem fb_mode_set
fastboot flash partition gpt.bin
fastboot flash bootloader bootloader.img
fastboot flash logo logo.bin
fastboot flash boot boot.img
fastboot flash recovery recovery.img
fastboot flash system system.img_sparsechunk.0
fastboot flash system system.img_sparsechunk.1
fastboot flash system system.img_sparsechunk.2
fastboot flash system system.img_sparsechunk.3
fastboot flash system system.img_sparsechunk.4
fastboot flash system system.img_sparsechunk.5
fastboot flash modem NON-HLOS.bin
fastboot erase modemst1
fastboot erase modemst2
fastboot flash fsg fsg.mbn
fastboot erase cache
fastboot erase userdata
fastboot erase customize
fastboot oem config carrier vzw
fastboot oem fb_mode_clear
Copy the file download below (thanks to SuperR and K RISE ) to the internal SD, then go into recovery and flash it.
https://docs.google.com/file/d/0B_DNsulDtL2_cC03Mm1CaDRIY2M/edit?usp=docslist_api
I went ahead and did a factory restore while I was in recovery. Reboot, re-config, reload.
Done.
