Here is a treat for you all
Soak ROMs [Lollipop 5.1] :
surnia_boost_51_soak.zip - Unmodified soak rom
surnia_boost_51_soak_debloated.zip - Debloated, rooted, init.d support, Eleven music player (CM 12.1), write to external sd from 3rd party apps, host file tweaks
Soak Partitions:
surnia_boost_51_partitions.zip
The partitions were updated in the soak test so if you want the full experience you should flash them too. If you update the partitions it will be impossible to get back to exactly where you are now (found this out on the Moto G). I am not saying that is a bad thing, just informing you
The ROMs work well without updating the partitions. So far I have not seen any negative side effects.
Other Downloads:
surnia_boost_51_hotspot_fix.zip - works on my device, otherwise untested. Need at least my TWRP 2.8.6.0 v2-5. It will not work with older versions. 2.8.7.0 is also good.
surnia_boost_51_hotspot_unfix.zip - works on my device, otherwise untested. Need at least my TWRP 2.8.6.0 v2-5. It will not work with older versions. 2.8.7.0 is also good.
surnia_boost_51_VVM_fix.zip - I have not tested this flashable but it does what I did to get mine working properly. Let me know how it goes. The only thing still not working is multi-select messages still FC's the app
Thanks to @K Rize for uploading the soak update.zip and an anonymous uploader for the updated backup
