I have not tried the 5.1 partitions with a 5.0.2 system.SuperR can we use the Soak ROMs partition zip with the stock ROM? Just so we get more internal memory space?
If I flash the partitions on 5.0.2 can I restore afterwards to the old partitions from a nandroid?I have not tried the 5.1 partitions with a 5.0.2 system.
If you flash the partitions you can't go back 100%. The bootloader can't be downgraded.If I flash the partitions on 5.0.2 can I restore afterwards to the old partitions from a nandroid?
That means that if I flash the partitions on 5.0.2 I will most likely brick the phoneIf you flash the partitions you can't go back 100%. The bootloader can't be downgraded.
If you have already updated the partitions to 5.1, don't flash the 5.0.2 partition updater. Feel free to try running 5.0.2 rom with the 5.1 partitions. Worst case it won't work and you can flash the 5.1 rom again.That means that if I flash the partitions on 5.0.2 I will most likely brick the phone
You are right but before I do this experiment would flashing the 5.1 partitions wipe the phone?If you have already updated the partitions to 5.1, don't flash the 5.0.2 partition updater. Feel free to try running 5.0.2 rom with the 5.1 partitions. Worst case it won't work and you can flash the 5.1 rom again.
The partition updater does not wipe the phone.You are right but before I do this experiment would flashing the 5.1 partitions wipe the phone?
Thats good to hear, I'll give it a try in a few days and let you know how it works!The partition updater does not wipe the phone.
If this is the case I should go worry free, right?I can confirm that after using the 5.1 partition updater you can still restore a 5.0.2 backup and it does boot up and can be used normally, I had to do this with my wife's E cause her phone doesn't like the 5.1 no root backups I made with TWRP
Wicked! A new deodexing method?Here is a test deodexed 5.1 part 2 rom. I am not able to test it so if anyone wants to give it a go, let us know how it works out
surnia_boost_51-2_soak_deodexed_1b.zip
Yes and no lolWicked! A new deodexing method?
I was actually wondering about selective deodexing (just the files that are most commonly themed, like framework-res, contacts, SMS, ect) instead of all of them to reduce potential issues..Yes and no lol
I used oat2dex.jar to deoptimize the odex files which is the same tool all the Windows lollipop deodexers use (java is cross platform). The 2 differences are:
1. I wrote Linux version
2. Based off the Moto G 5.1 rom which is deodexed out of the box, I did not deodex the entire framework directory. Only the files that have associated *.odex files in the /framework/arm directory.
All of the apk's are deodexed. The only thing not deodexed is a handful of framework jar files.I was actually wondering about selective deodexing (just the files that are most commonly themed, like framework-res, contacts, SMS, ect) instead of all of them to reduce potential issues..
Does deodexing make the phone boot faster?All of the apk's are deodexed. The only thing not deodexed is a handful of framework jar files.
No, it only enables theming capabilitiesDoes deodexing make the phone boot faster?
Exactly, well theming at the XML and smali level(not necessary for just image swapping) anyway...I've actually almost always found deodexed roms a bit slower at first till they've settled in.No, it only enables theming capabilities
Does the new deodexed rom work?Now I can take a crack at the extended reboot menu and AOSP status bar. Thanks @SuperR. [emoji106]
