I have tried to follow these directions I can get to item 6 with no issues but I can not get to the directory in number 7 I can get to c:AndroidSDK. I can not get to the tools section what am I doing wrong what do I have to have opened and where do I have to put it to get this to work. I appreciate all the help and you would think I could do a simple thing like this with these instructions but I am at a lose as to what the heck to do!
Installing the SDK and using ADB
1.) Make sure debug mode is enabled:
Menu -> settings -> Applications -> Development
Check the box for USB Debugging.
2.) Download the SDK from Android SDK | Android Developers
3.) Download HTC Sync from HTC Mobile Phone Support - DROID ERIS by HTC (Verizon) - Downloads
4.) Install HTC Sync (This takes care of any driver issues)
5.) Extract the SDK to any directory (C:\AndroidSDK is easy to remember) and install.
6.) Open a command window (Windows key + R -> Type "cmd" hit enter)
7.) Navigate to your SDK\tools Directory Code:
cd C:\AndroidSDK\tools
8.) ADB commands will work from here
Installing custom boot animations (Credit to jcase from XDA):
Windows:
1.) Download the desired animation, rename the zip file to "bootanimation" and move into your Android SDK/Tools folder.
2.) Run the following adb command to push the animation into the proper place:
Code:
adb push bootanimation.zip /data/local/
3.) Enjoy!
Windows:
Code:
3.) Enjoy!
