Help boot animation problem.help.
mrblings
i have .png files all ready to go in part0 folder and part1 folder, but i can't get it to work with bootanimation.zip. i read all the instructions on how to put it in data/local from root explorer but the one that I MADE doesn't work......
i was thinking maybe it's the size? or the desc.txt problem? can anyone check my stuff?
and yes. i used 7.zip..... can someone make me using the pics inside my zip?T_T it can be different sizes btw
bootanimation.zip
