Root Boot Animation
I was wondering if anyone has successfully changed the Boost Mobile Boot Animation on this phone. BAC (Boot Animation Changer) has not worked for me so far.
I am rooted.
Yeah. Just replace the boost boot animation zip located I believe in system/resources/customize or something like that with a boot animation package that you want. Make sure to edit the permissions to match the original, that the resolution in the text file matches for your screen, and that if you make your own zip that compression is turned off otherwise it'll be blank.
it worked like a charm i downloaded root explorer from rapidshare changed the permissions renamed the file bootanimation.zip as it said something else,deleted the original boost animation after backing it up to my computer copied and pasted exactly the way guyphs said and rebooted it worked like a charm....right now i have a star wars\android bootup i downloaded thanx to someone else that i shall give credit to shortly in an update seeing as i just closed the window in which i found the file
find the file i have and more for custom bootups here http://www.google.com/url?sa=t&rct=...84CgDA&usg=AFQjCNErH4WRfCzEOAfWMsAUz-4WPUrMjw
I heard developers get this app for free but i didnt have that kind of luck so i just went here and downloaded instead.....http://rapidshare.com/files/3641790870/root_explorer_file_manager__2.17.2.apk
hope this helps all with such a small issue
found an even better should the above not work for you...go to the market b.k.a. google play download an app called boot animation(it should be the first rainbow like X at the top of the list) and its pretty simple and self explanatory...but just in case download or install the file its only temporary until you pick your next bootup animation hit the menu button after install completes hit preview and enjoy
