Boot animations........HELP!!!
somekid13
Ok so I have searched around.do you need to root to change the boot animation? If not where can I find some other ones. Thanks in advance.
Sent from my Droid using Tapatalk
Ok so next question. Can you use astro to load it on there because I found the bootanimation.zip file and was just wondering. Thanks again.
Download a custom boot animation and try moving it to that folder. That'll give you your answer.
You might want to rename the original one bootanimation.zip.old, or something like that.
Sent from my Droid NOT using Tapatalk. :cool:
Ok so come to find out that the boot animation part is read only. Looks like I am gonna do it the other way.thank you guys.
Good luck. I promise, as long as you follow the directions scrupulously (I recommend using cut and past for the commands) you should have no problem getting a custom boot.
