Root boot loop after repartision. sm-t217s Fixed
antdogac
Member
Ok so i rooted with king root then i used a deleated knox then i tried to flash cwm recovery with an apk called rasher but apparently knox write protection is still enabled. Oden is getting stuck at 1 percent and i cant get kies lte or kies 2 to read it either.
Up date. Ok so what happened was i had windows deffender still on. So i had to drop windows deffender that took care of writes protection. Then i was able to flash the stock rom but i messed up and cheacked repartision so it wasnt monting data at all. I was in a bootloop from hell. I flashed cwm recovery and installed seals rom same thing bpotloop data mount error. Twrp with aromoa rom. Still boot loop. I flashed super user frpm the recovery and nothing. Tje way i fixed it was i used oden 9 to flash stock tar but i used Ap setting not pda. I had auto reboot off and it took about ten mins. Then i booted into stock recovery and i already had the same stock firmware tar i just flashed stored on my sd but in the form of a zip. File then i installed update from external and vawala. Fix. Im the King. Naw i suck but if this helps any one out i dont mind posting it
