Root boot loop help .... Fix everything by turning your phone into an Evo 3d
jgriner
Member
i was trying to flash the hboot, and now in boot looping. :(
I do think the hboot went through because it says hboot 1.04.2000
after running from zip file, it started boot looping, I had to pull the battery to get into bootloader. Once its in the bootloader it automatically looks for the pg56im.zip file, then asks me if i want to continue, if i chose no it forces me to reboot, if i chose yes it loads the file. Either way it goes back to boot looping.
to load into bootloader, I had to pull the sd card, and move the pg56im.zip file into a folder. now when i reboot, it looks for the zip file cant find it then takes me back to the bootloader screen.
what i have tried.
wiped cache, and dalvik, no good :(
wiped cache and dalvik, reloading rom, no good :(
reistalled from backup (made just before starting this) no good :(
factory restore no good
suggestions would be great, thanks
what i have tried.
if its possible to hook up your memory card to your computer with the need of your phone you can try to flash the juponutbear 1.58 hboot, copy the file to your sdcard and try flashing that.
