Ok, now I got RSD Lite to see the phone, tried flashing 2 different SBFs but they both failed
A. I was using RSD Lite 2.6 on a Win 7 64 bit machine
B. I was using lower versions of sbfs than 2.3.340
Both are downloading as we speak.
Summary of what I did...
I first downloaded Droid X bootstrapper
I then downloaded Droid 2 bootstrapper because I read you needed that one to install GB roms
I booted into recovery, made a backup and rebooted
I booted into recovery, installed 1st .zip successfully, 2nd .zip failed, I rebooted and found myself in boot loop
I tried all boot into clockwork tricks I could fine
I tried flashing 3 different SBFs, all failed
It might be a messed up file. Try redownloading part 2
Ok. So after the sbf flash worked, I rooted again, installed Droid 2 bootloader, installed that, rebooted into recovery and tried installing the 3 files again. Once again, it failed on 2 and I have to use RSD lite to recover again. What am I doing wrong?
Here's a thought. If you are using Droid 2 Bootstrap, you *must* have USB Debugging enabled for it to work properly. There are differing opinions on whether to used Droid X Bootstrap or Droid 2 Bootstrap, and it seems to revolve around USB Debugging. I'm not a tech expert by any means, but I can tell you that I've used both bootstraps successfully - but only with the proper formula: Droid X Bootstrap = USB Debugging OFF, while Droid 2 Bootstrap = USB Debugging ON.
I'm not sure if this has anything to do with your problem, but thought I'd throw it out there for comments.
-Mike
If he were using Droid X Bootstrap without debugging, then he simply would not be able to boot into CWM. Of course we know that D2 Bootstrap will work fine.
If you're talking about a Gingerbread rom on the Droid X, I am currently running Liberty GB v.4 and I *always* boot into CW Recovery through Droid X Bootstrap, with USB debugging off. Do it numerous times each week, without a hitch. I was trying to clarify a point for the earlier poster, and as I've said many times, I'm no tech expert, so if the way I do things on my DX doesn't work for other people, I apologize up front.
For my phone, Honest-To-God, I use Droid X Bootstrap with USB debugging turned off - and it works!
-Mike
Hey Mike,
Don't be offended by my post. It wasn't meant to belittle you or question your experience. I try not to do that. I just wanted to add that you will know that you are using Droid X Bootstrap wrong if you can't reboot into CWM. There are enough of us with knowledge in here that we can compliment each other's posts. I have folks come behind me to clean up info all the time. It's a great way to become an expert.![]()
I was anxious to be clear that I've used both bootstrappers with equal success, using the Off/On formula I listed in the earlier post. I'm essentially an end user, with no formal training - but I've become pretty proficient at rooting, installing roms & themes and generally tinkering with these phones (I have 3 different android phones). That being said, I am perfectly capable of overlooking the obvious, and have had to sbf as recently as Easter weekend, so I tend to offer advice with caution and qualifications ("Well it worked for me, but YMMV"). I am in a constant state of learning new things, and that's why these forums are so cool - the Peer To Peer help.Hey, no offense taken!I was anxious to be clear that I've used both bootstrappers with equal success, using the Off/On formula I listed in the earlier post. I'm essentially an end user, with no formal training - but I've become pretty proficient at rooting, installing roms & themes and generally tinkering with these phones (I have 3 different android phones). That being said, I am perfectly capable of overlooking the obvious, and have had to sbf as recently as Easter weekend, so I tend to offer advice with caution and qualifications ("Well it worked for me, but YMMV"). I am in a constant state of learning new things, and that's why these forums are so cool - the Peer To Peer help.
-Mike
Search for rooolers guide, it'll walk you through step by step. I'm on my phone or.else I'd give you a direct link
