You need to dish out a lil more info, I'm guessing ur completely stock since I don't believe any rom has the virgin mobile sounds
Did u do anything to the phone system wise, like root and play around in folders
If the phone is 100% stock I believe if u pull the battery during startup it should set system to defaults
If it is continuing to bootloop it could be hardware related
