ramjet73
Android Expert
The firmware, recovery and hboot in joe_blow's thread are as current as you can get and still run GB and AOSP based ROM's. The firmware is based on the official VM updates and not a really old hboot and firmware that came from different Sprint GB builds for the radio and PRI. Everything I've read says that the radio and PRI should be in sync since they are designed to work together. Here's one post that documents that and I've seen others.Before I rooted (like a week ago) I installed all updates. Prl, profile, firmware. All the HTC software was updated. So what would the stuff in Joe_Blow's thread do compared to Leslie Ann's thread?
If you've already updated everything to current levels there's no need to do anyone's "fix everything" thread.
Any particular reason why you prefer to flash a very old hboot, and a GB radio and PRI individually instead of flashing the most current stuff in one zip file?Near as I can tell it would basically simplify the steps in her thread, but personally I still prefer her method.
From the OP of the original "fix everything" thread:
Note that the PRI is from the Sprint GB 2.17.651.5 build and the radio is from the 1.13.651.7 Sprint GB build.What we will change here are:
ENG Hboot 1.04 - allows other roms and needed for the radio flash. Engineering hboot, more recovery options, less restrictions.
PRI 2.17.651 - fixes some fluctuations, increases radio strength. This will show up as 1.53_145 in about phone.
Radio 0.97.10.0530 - fixes some fluctuations, increases radio strength. (Updated, much better!)
PRL 60690 - Updates the list of towers you can connect to (Optional but highly recommended).
Note: You can change to any Hboot once you are done with the radio, and PRI flashing.
Just curious.
ramjet73
