Boot Problems with AOSP FROYO
jwolfe152
Member
ok heres the deal i tried a few new "market" apps so i can try stuff before i bought it to make certain i would like the additional options. well i was using Applanet well just about EVERY 3rd party app said it needed updated well i tried to update a few of them wouldnt let me cuz they were up to date well after downloading a few new apps to try i go and reboot normally took longer than usual to boot.
well it booted went to the lockscreen and then rebooted again and then it got stuck on the bid ol devil screen (im using the dark cherry thme something like that) and have to do a battery pull to reboot well sometimes it just sticks or it will boot up fine or it will boot up to the lockscreen for about 20 seconds then auto reboot.
BTW i also did a nand back to before i installed applanet and its still doing it. now my question is could applanet done something to my boot files or could it have added something to the sd card thats messing it up...i really dont know if the sd card is read on bootp or not.
btw im downloading a sense rom (liquid) to update my PRL and Profile and i want to format the sd card start with a clean slate because im also going to download the new GB rom.
and another question but this is about the sdcard. when should i format my card? ive got nandroids and rom images and everything on my PC for if somehow my sd card goes and need the stuff in a pinch.
if something doesnt make sense just let me know i will try to clarify it the best i can thanks for the help and reading this long crap.
