theisonews
Hi i did the button combo, it goes to the LG screen , i press power 3 times then it goes to a black screen
plz help.
plz help.
Your not doing it right. Turn phone off completely, make sure its actually off and not rebooting. Then hold the power button and both volume buttins until the phone vibrates then ONLY let go of the power button until a black screen asks you if you want to perform a factory reset. Press the power button 2-3 times. It should say confirmed, then itll boot into your recovery. Or you can get an app like quick reboot from the market or romtoolbox or rom manager
Edit: nvm, forget that text. Read too fast. Sounds like your recovery is gone. Download rom manager and
i can't do that, i wiped and formatted all. i have no OS.
what do i do now?
what do i do now?
That sounds next to impossible.... did you have cwm up before or was it the stock recovery you booted into?
