make sure youve unchecked "fastboot" in settings/power. it will prevent you from getting to hboot via power/vol down from a powered off state.
to get to hboot from simple powered off with fastboot unchecked,youll need to wait several seconds/couple minutes to make sure the phone is really off. even with fastboot unchecked,holding vol down/power before the phone has shut completely off usually does cause a normal reboot.
i find it easier to boot my one X to hboot by doing a hard reset:
-hold power till phone turns off to reboot
-when the screen goes black,press vol down,let go of power
-let go of vol down when you see hboot
