hey... I have a HTC Inspire 4G. Details are given below:
Android Version: 2.3.5
Software Number: 3.20.502.63 710RD
H-Boot: 2.00.0030
Radio: 26.09.13.17_M
S-Off
Bootloader Locked! and not Rooted (Because I can't connect it to Computer, not solving driver problem
Today I read from here that I can install RUU by renaming the zip file to "PD98IMG.zip" and placing it to SD Card and rebooting to Bootloader... It works fine when I tried it on the ROM from HTC Download website of HTC Inspire 4G but it can't work with any other zip file I tried... If I put zip file of another ROM and boot to bootloader, then bootloader does Load the zip file but after loading it, it shows the sign "Parsing the zip File"
and then next go to boot menu...
The point is,
> I can't connect to computer there for No Bootloader-Unlocking and Rooting
> Not only windows, mobile can't connect to Ubuntu... I have tried EVERYTHING
> I want to install ROM which is based on Android 4.0+
Can I take advantage of S-Off ??
H-Boot: 2.00.0030
S-Off
)Today I read from here that I can install RUU by renaming the zip file to "PD98IMG.zip" and placing it to SD Card and rebooting to Bootloader... It works fine when I tried it on the ROM from HTC Download website of HTC Inspire 4G but it can't work with any other zip file I tried... If I put zip file of another ROM and boot to bootloader, then bootloader does Load the zip file but after loading it, it shows the sign "Parsing the zip File"
The point is,
