Root Bootloader code corrupt... Cant flash sbf...Help!
philc21
I tried flashing my phone and it failed at the end and now I'm getting a Bootloader error and I cant flash and get my phone working again... I'm hoping someone can help me from this error log:
14:19:57, April 27, 2011
Line: 378
ERROR: Error getting subscriber unit information.
File: X:\test_dev_usb\flash\code\flashdll\SUInfoOp.cpp
Line: 378
Line: 384
ERROR: Phone[0000]: Error getting subscriber unit information. Device API Error: 0xE0030009 Command: RQHW
Device ID: 0
Line: 1182
ERROR: Phone[0000]: Flash failed.
File: X:\test_dev_usb\flash\code\flashdll\PST_FP_FlashTh read.cpp
Device ID: 0
Line: 587
ERROR: Flash failure: Phone[0000]: Error getting subscriber unit information. Device API Error: 0xE0030009 Command: RQHW (Error Code: e0030009),
Detailed Error Details: Direction of the Error=1000, Command Value=800000, Code Group Number=No Codegroup
File: X:\test_dev_usb\flash\code\flashdll\FlashHdlr.cpp
Device ID: 0
Any help would be really appreciated!!! before I have to go buy a new phone
Can you list out the best you can exactly what you did when flashing your phone (ie: what you used, type of computer, sbf file you flashed etc). The more information you provide the better someone can help you.
Sorry, I would offer more, but this is gonna be beyond me:(. Worry not though there are a number of people here who can help you.
My suggestion would be to do a battery pull first and see if the normal bootloader screen comes up. If it does, download a new/different SBF file and uninstall RSD lite and reinstall. I have had the best luck using RSD ver 4.8 myself. And like the previos post stated, the more info you can give us the better. Good luck!!!
+1 ^^^ this. I am also not too familiar with RSD Lite error codes, but let me be even more specific in the questions:
1.) Exact phone model and best estimate of firmware on it before
2.) Exact flashing software you are using and version number
3.) Exact name of the .sbf file you are trying
4.) Exact version of the OS on your computer
