Root bootloader help
colossus3874
ok so I had to get a replacement phone and going through the process again. Problem is, when I try to get the bootloader unlock token, the command window won't let me copy the token!! I right click, hit mark, highlight the text, but when I right click again, it clears the marked text and I can't copy. What am I doing wrong here?
It's been so long since I've done this but after highlighting the token use control-c to copy and see if that works for you, good luck.
OB
Still clears the highlighted field. If I can't root it soon, I'll probably move on. I need root so my wife can use WiFi for school
Highlight by dragging and don't click anything again. Then hit ctrl+c on the keyboard.
Then just paste the code into the htc Window with ctrl+v
Thanks. That worked perfectly. I am now rooted with Harmonia back on the phone. Haven't decided if I'm going to re-do s-off or not as last time it gave me many problems. Thanks for the help!
