jdailey1981
Is ther any way I can reset the bootloader? I accidentally hit to install a kernal before a rom, and now I have to use fastboot into everything from PC. Whenever I go into bootloader, it keeps going back to "parse update", which is that Kernal, and it keeps on wanting to update this. When I do this, all it does is stay on the splash screen of the ROM......
BTW, I went with Nils Business ICS Sense 4.0
all you need to do is put your sd in a card reader,put it into the PC,and then eliminate PH98IMG.
