Root Bootloop after Tacoroot, Revolutionary + TWRP
I am helping a friend with his HTC Incredible 2. Helping may not be the best choice of words.
Long story short --- he was on android 2.3.4 and wanted to root. He called me.
I used Tacoroot to downgrade to 2.3.3 and the Revolutionary (windows version) to obtain Beta Key and installed CWM.
Apparently this method does not properly install CWM and I have a bootloop when I try to power on the phone. I wish that would have come to my attention sooner.
I finally was able to flash (command prompt) TWRP. I used the image file marked 2.3.3.0 because that matches the android version of the phone. I am not sure if that matters.
Still ... I can get into TWRP. However, the bootloop still persists. I think I need to flash something using TWRP, but I am not sure.
What next? He is ok with flashing a custom rom. Is that what needs to be done? Can I flash the stock rom again? Does it matter which?
Any help is appreciated!
Also, In the (white screen) HBoot recovery screen a quick script is run in bootloader saying something along the lines of no image or wrong image.
Beezerhale. I know this is now almost an year long but I am working with my Incredible 2 and I have exactly the same problem. I've been searching forums for an answer at not avail. Do you remember what Radio flash fixed the problem? Thank you!
