Use the fix
http://androidforums.com/motion-4g-...rick-lg-motion-unroot-getting-1-5ghz-kdz.html
Oh, and don't reinstall Beats Audio ;-)
I did everything and allowed it to charge but now its Stuck on a black screen
Please help me !
try a factory reset
from powered off state
hold vol down and power, until you get to a screen that asks if you want to do a factory reset, it takes about 10 seconds for this screen to come, so just keep holding the buttons, then press power again twice when you do get the screen
make sure you have loaded the version D firmware that sammyz has provided
http://androidforums.com/motion-4g-all-things-root/608228-official-motion-4g-10c-d-firmware.html
because this factory reset is not available in version C
try a factory reset
Okay so I tried that, tried flashing the D Firmware and factory resetting and I mean I can see the little battery animation when I put the charger on my phone but, when I turn it on the LG boot animation goes on once for a short bit then the second time for the full time then quickly blinks and does it for a really short time and then It just goes to a black screen . Should I just leave it there ? Is this supposed to happen ?
He needs to boot into download mode.
Pull battery and unplug it.
Put battery in, hold volume down and volume up and power. Plug into PC. Start unbrick process.
