Help Bootloop Problem
I use an Alcatel One Touch Pop Astro. I received an update to it dismorning, and it said 'Failed to upgrade' Now it is stuck in a boot loop. It will say 'Android is upgrading... Optimizing application 1 of 48' The phone will reboot after a few seconds, and go right back to that same screen. I have booted into the recovery screen and wiped data and cache multiple times to no success. It has now been sitting here for hours plugged in and constantly rebooting. This is my only phone, and I don't have the money to buy a new one right now. How am I supposed to fix it?
Assume you are rooted going into the recovery or is that a stock recovery? If rooted with a custom recovery it sounds like you tried to update official update which could be the problem. Try flashing a different ROM or restore backup?
If it isn't rooted and you are running stock etc I would suggest a Factory Reset and wipe. Seems strange that it is getting past the point of bootloop, ie the system is actually started and upgrading, then resetting itself. I have no experience with Alcatel at all unfortunately so hopefully someone with more know-how of the device will be along soon.
Does it have a removable battery? If so, it's worth pulling it out for a few minutes. Probably won't help, but there's a chance and no downside.
Otherwise, it sounds like your only options are:
1) full factory reset (which will erase everything)
2) contact Alcatel, or your carrier if you bought through them, and tell them that their update broke your phone so it's their job to fix it. They'll still wipe the phone in the process of fixing it though, so you've nothing to lose by trying the factory reset.
That is unless you've rooted it or otherwise modified your system software, in which case actually the truth would be that you broke it by accepting an over the air update on a modified phone. If that's the case it's probably best to find out how to reflash the phone to stock yourself before bothering the manufacturer, though that's still the final option if you can't fix it.
(Edit: or, as SavageRobot says, if you are rooted and have a custom recovery then flashing a new ROM, or restoring the backup if you have one, is also an option).
If you've not modified it then reflashing to stock yourself - however that is done on an Alcatel - is also an option. But if their update broke an unmodified phone I kinda think they should be told about it and should take responsibility. Note that if you bought it through the carrier and they customised the software then the update came from them, rather than directly from Alcatel, which is why who you should contact could depend on who you bought it from.
I did root it at first but I decided to revert as I had no need. It is stock ROM and recovery. I have already tried all of your suggestions to no improvement. Right now the tech support people at Walmart (I bought the phone through Family Mobile) are working on it. I will report when I get the phone back.
Hello, I'm planning on getting this device, and I do want to root it, would you be so kind to tell me what procedure you used? Was it an app or via PC? Anyways, regarding your problem and if Walmart can't fix it, you can always try flashing a copy of the firmware in an .img via fastboot, the thing is getting a copy of said firmware...tell you something, if I do get my hands in an Astro and you're still in trouble I can help, though, another question, when you were updating the OS, were you switching from KitKat to Lollipop? Thanks in advance, and good luck.
