Root Bootloop with das BAMF 1.10 PLEASE HELP!
Hello everyone,
I have been reading these threads for a while, getting prepared to root my Thunderbolt. I rooted about a week ago with Revolutionary and had no problems whatsoever. A couple days ago I flashed my first ROM (Gingeritis) using the instructions on this forum, and everything worked great, except that I accidentally restored some system data with Titanium Backup, which I read can cause FCs, etc.
Therefore, I restored the stock ROM by booting into recovery and following those steps. Again, everything went well.
This morning, I wanted to try out a different ROM, so I followed the same steps with das BAMF 1.10, and I flashed the ROM successfully with no problems. However, after restoring my contacts (one of the green pieces of system data that I thought were ok to restore) with Titanium Backup, the popup "Sorry!" repeatedly came up saying that the application.com.android was not responding and needed to be force closed. It came up again so fast after clicking "close" that I couldn't even reset. Finally, I pushed the power button at the exact right time to be able to see the menu of options, and I clicked restart (not in recovery).
Now, the phone is running through the das BAMF and HTC startup screens repeatedly. The battery is pretty low. What do I do???
THank you so much! I really really want to resolve this and avoid bricking my phone like an idiot.
-Matt
Pull the battery. Hold power down while simultaneously holding volume down. Then select boot into recovery. Reflash your rom.
