Root Bootstrap Recovery for locked Photon 4G: backing it up
jondon156
My question is this: Can Bootstrap Recovery backup a locked Photon 4G and can you flash that backup to the phone?
qbking77 has a youtube video for installing bootstrap recovery on locked photons but he doesn't say anything about backing it up.
He says that you can't flash roms that need an unlocked bootloader, which i know but does the bootloader need to be unlocked to make a backup and then when the time comes can you flash that backup back on the locked phone if it glitches?
Any input would be great. thanks.
If you have Bootstrap Recovery installed, you should be able to make a nandroid backup using the app without unlocking the bootloader.
