Hi
Cn anyone think why this should be difficult?
My Galaxy SII pairs OK with the Bose Soundlink over Bluetooth but the Note will not pair with it - The Note does not indicate it can see the Bose device. I have set Bluetooth on and made the Note and Bose visible.
The Note is using
Android 2.3.6
Baseband version N7000XXKK5
Kernel Version 2.6.35.7 N7000XXKKA-CL 726566 root@DELL87 #2
Build Number GINGERBREAD.XXKKA
KIES Air is also not working, can only xfer files with cable, like upload music.
Apart from these two glitches, pleased with the note but I am trying to choose which to keep and these factors could mean that the Note goes...It is an unlocked handset bought at Carphone Warehouse in the UK, used with an old Orange account.
Thanks
The Note is using
Android 2.3.6
Thanks
