Help bottom plastic cover of the phone is loose.. HELP!!
decks19
Ok so i went to pick up my phone and felt that the bottom right portion of the phone where the mic is on the front had some play. Its not noticeble unless you actually touch that part. And now that i know its there its bugging the heck out of me. I would like to know if anyone has this same problem. Or is there a way to fix this? i would really like to know.
It's never been dropped or banged.
Mine has the exact same problem. It bugged the hell outta me too, until I got the silicon case from verizon. I no longer notice it because the case is pretty solid.
