Root Brick Bionic
So after getting my Bionic, first thing I did is rooted it. Well after exploring around, I found a thing called TeamBlackHat and the Bionic Toolbox. I was using the toolbox to change various thing such as my battery indicator. Well I realized I didn't like the animated, so I went for a static indicator. Partly through the download of the static ones, I lost internet connection, but then regained it. It stayed at the "working" screen for a good 15 minutes, so I figured it to be a network bugged and closed TBH and opened it back up. When I did, it showed that the static ones were done downloading, so I applied one. After loading, it restarted my phone. That's where we hit the snag. It now constantly stays at the screen with the red "M" and says "Dual Core Powered" What can I do to fix this? I already tried going into recovery, clearing cache, and wiping data/factory reset and I still get the same outcome.
Thom is right, this should be in the root section.
BUT...
here is my favorite link to re-post
[FIX] Bionic (Boot FAILURE) & (CDT FAILURE) - xda-developers
make sure you follow ALL the instructions. This will fix your boot-loop.
*edit*
I just thought of this as I hit post.
Pull the battery
When you reboot press the power, vol up and vol down
you see the android out of the box image
press vol up and down again
this should be stock recovery
scroll down to the bottom option (vol down)
press power.
If that doesn't fix your issue try the above link
