Root Brick?!(photos)
yes its brick i think...well i cant boot up the phone it just stays like that..even when im charging it and when i try go into recovery mode and failed tried many times plz help me =(
when i turn on the phone
View image: HNI 0017
when i press recovery mode for 20 min =_=
View image: HNI 0018
Hello This may sound totally crazy..... try a battery pull with the battery out hold the power button for 20 secs then put the battery back in and restart it....If it was the boot animation I would think it was bricked but The LG splash can be due to alot of stuff.... But I remember reading about a problem that happen with an lg ally but the same principal should apply
I followed your steps
1)take out battery
2)hold power button for 20 secs
3)put battery in and turn on the phone
it didnt work but thx for trying to help =D
1)take out battery
Dont give up hope yet there should be a way to get the stock software from the lg website... i am not sure if the phone has something like fast boot off the top of my head.... i will do some research when i get home and take a look at my brothers phone you maybe able to use lgupdater i will look the link when i get home unless you can search google....
lol thx i tried the lg update and the pc wont recongize also
does rooting cancel my warranty?
First off sorry to say it does void your warranty thats the big disclaimer you read on all root guides....
I may have found your light at the end of the tunnel......
DISCLAIMER: I am not be responsible for the following/but not limited to:
You brick your phone
You damage the phone.
It doesn't work for your phone
You smash your phone from frustration
You drive over your phone from frustration
You throw your phone against the wall
You drop it in the toilet
Your computer crashes
You get hit by a car
You get hit by bird crap
Your girl/boyfriend dumps you
You get robbed in the middle of the night
In a nutshell I am not responsible for anything that happens following this guide.
YouTube - how to unbrick lg optimus t ( look at the video description ) Thanks david913250
Here is the directions
download
Stock-Factory-Optimus_T_Flash.zip - 4shared.com - online file sharing and storage - download and extract it and install msxml also install LGUSBModemDriver
then plug your phone to the computer and then take the battery off your phone put it back and turn it on holding ((volume up+back or try volume up+home)) its gonna take you to a green screen where it say emergency mode
then while your phone stills on emergency mode install adb from here: What Is ADB And How To Install It With Android SDK
when your done with adb set up, open KDZ program from the first download i gave you and
set the options to this
type:3GQCT phone mode:emergency
now click the little folder where it says browse and chose V10L_00.kdz this file comes from the fist download i gave you when you browse the file click on launch software update and let the program do its thing
if it doen't work and says phone not found just tell me))and if it does its gonna take like 5 to 10 minutes when its done its gonna reboot and take you to a recovery mode and dont touch anything from that take off the battery and turn on your phone normaly ,its gona give you a factory reset how it came out new
when i take the battery when its plug in the computer its still on.
and when i turn it on, i have to take out the battery if i want it off
I havent tried this but i think it means turn the phone off then plug it in do a battery pull the put it back in then follow the steps to turn it on in emergency mode
more photos about the latest comment u said
Battery is pulled out and phone still like that
ImageShack® - Online Photo and Video Hosting
just proof that i took it off =D
i put the battery back on unplug the usb still works
also i ask the person in youtube if he can do a video like he show it himself =0 which makes thing easier?
I will do more research this is bugging me now i am going to solve this issue if it kills me ha from the pics it looks like the phone was turned on before you pluged it in or did it turn on when you plugged it in try turning the phone on in emergancy mode without plugging it in first then if it goes into emergancy mode plug it in
with and without battery i cant do it no matter what, i cant turn off by pressing the button...
i cant enter emergency mode i press home+vol up and back vol-
and it takes me to the lg screen this is my attempts
1.turn on then i press vol+ home for 10 sec then i take out battery and turn on again
2.same thing as number one but vol- back
3.i press them all together and wont work
4.when phone plugged in turns on by it self when battery is there , take out ,then plug it back in and nothing happens also plugged out battery (yeah its still on :mad:)
5)i really starting to throw my phone at the wall,burn it,then throw it in the toilet.
Let me do some more research can i ask what did you do to the phone before this started happening
ok i rooted my phone perm then i installed recovery mode thing after that i made a back up after that i installed cyanogen 7 then i rebooted it.It became a infinte loop not the lg logo android like it regular does after that i did recovery I ran back up but it kept saying fail (dont remember)then i turn off my phone went to sleep.The next morning i was getting ready for work turned my phone and it became the BRICK phone Q_Q i cant access any thing even my recovery mode and yeah this is how this thread was made
This may seem like a stupid question but when you flashed it did you clear the data and cache...... if not that may be you answer...... do you know anything about adb? just wipe your data using that.....
If that doesn't work try this [HOWTO] Flash original firmware on P500 - xda-developers
i quit srry :eek: but im gonna get a new lg optimus t this time not gonna root it just gonna use my phone and wait for the gingerbread update thx for ur help srry for not posting this long ago
TY tattedman :D
TY tattedman :D
Sorry I was unable to help If I was able to have the phone in my hands It should take me like 10 minutes to fix.....
I read this post and was in the same situation with the individual. I was very disappointed that I could not unbrick my phone inspite offollowing your repeated suggestions. I think, I needed afile to complete the process in using the KDZ program. Do you happen to have a copy of "V10L_00.KDZ"? Right now, I'm stuck with a blue screen with a message:
Fastboot mode started
gpio_i2c: invalid khz: 0
bI: i2c write error
udc_start ( )
Do you know how to get out of this mess?
I rooted my phone with SuperOneClick 1.9.1
then I use Rom manage with CWM 7, that's where I messed up my phone.
Please help.
Ok I don't know much about the phone. Iv only installed CM7 on it.....
Here is a couple things I found...... don't worry if it calls it a different Optimus that is due to the different carrries.....
ie Optimus T = Tmo
Optimus S = Sprint
If these guides don't work or would like me to explain it better my gtalk is
tattedman88@gmail.com
[HOWTO] Revive a bricked P500 on fastboot mode (the SHORT way) - xda-developers
xda-developers - View Single Post - Cannot Boot up LG Optimus M
The only time I bricked this phone was awhile after I installed it I had to boot into safemode and then power it off and it worked fine.
It looks as if you may have flashed the wrong recovery. Don't panic (yet)
I have also subscribed to this topic so I can keep track of it.
