Slashbeast24
Put my bionic in Flash mode and when I came back at the top it says AP Fastboot Flash Mode (S) (Boot Failure)
Battery OK
Ok to Program
Connect USB
Data Cable and then under that it says:
Invalid CG OTV (CG:webtop) Invalid SP Data
Invalid CG HAB (CG: webtop, status: 0X004e)
Invalid CG OTV (CG: webtop)
All this happened after I tried to SBF (I call it that after coming from a Droid X, I know it's something different now)
It's bad enough when I have the phone plugged into my computer RSD Lite tries to tell me there's not enough space on my hard drive to uncompress the 902 file until I restart my laptop but this is pretty bad too.
So am I completely screwed or can this be fixed? Any help is appreciated!
Battery OK
Ok to Program
Connect USB
