Ok, let me see if we are on the same page. You ran the RUU and are now back to stock. You have s-off. You reran unrevoked a second time and still no recovery. You tried to use hboot to flash the PC36IMG file and it failed. Is that where we are at? Did you make sure you didnt accidentally name the file PC36IMG.zip.zip? Windows hides extensions and it is easy to do.
i just reran unrevoked 3 and it said "Error: failed to get root. Is your firmware too new?"
As far as the zip goes. I did what the guide said and named it "PC36IMG.zip"
. I knew you'd get it fixed. I figured this was the state your phone was in. Now that you've got everything backup, one quick suggestion - when you flash the ROM (myn's) and the radios, flash them one right after the other. You shouldn't boot up a 3.70.651.1 based ROM (e.g. myn's RLS5) with the older radios. It might boot up, but it will be unstable if it does. So, you should flash the ROM in recovery, then without rebooting flash the radios, and follow the instructions. Wipe cache, dalvik, and data, of course.
