Root Bricked my Droid X, and now RSD Light wont recognize it!
What's your problem. Just so happpen I had already been through this problem plus I was just sitting around watching football. The guys on this forum are the best they will always help. I know you were just teasing but I can guarantee you somebody will help.
Do you mean the words instead of icons? I used LPP but not sure if any of the other after market apps will do the same. You first can download the icons at http://www.droid-den.com/android-guides/android-tallmin-icon-set
Those icons will end up in your gallery. On your dock long press the icon you want to change, Then choose change icon, then choose custom icons and pick from your gallery.
Nick, check your private messages. I need your email address so I can send you the Fancy Widget APK
Nick, just sent the email. You can easily have different icons in each dock using LPP. Since this method just uses pics from your gallery you can even use photos you have shot.
Seems like it will work with Launcher Pro, if I could just find out where these Icon Packs I downloaded from the Market were saved to...
Hey gfsincere, my post to you didn't exactly come out right. I meant to say Do you have a problem with your Droid, not What's your problem. I'm not that kind of person. Sory if it offended you. e glad to help or get you help next time your Droid needs it.
Merry Christmas
I'm just going to stick with Apex, no additional Launcher. However, I somehow switched the main Icon on the dock to open up Maps, instead of the App Tray. I cant figure out how to change it back..hmm
And I somehow got a picture on the main Icon for the dock, and cant for the life of me take it off.
Did you click on the menu and check preferences. I haven't used ADW Launcher which comes with Apex but it has many of the sme options as LP. Might want to start a thread asking about ADW Launcher on Apex. Probably can get the info you need.
