Bricked my phone. Then fixed it.
keredini
Member
Long story short, after rooting my phone and customizing it exactly the way i wanted it, i decided to see if I could get Mimocan's lag-fix to work on the Captivate. For those that don't know, this speeds up I/O by placing the some of the inner workings of the phone onto a EXT3 (or 4) partition on the SD Card. Some users have seen benchmark scores double using this method on other versions of the Galaxy S.
I was too anxious though and didn't read through all the forums, as seems like Captivate owners trying this method have bricked their phones. For me, I was stuck so that no matter what happened when I booted up I went into recovery mode, however from recovery mode i couldn't select any of the options.
I finally found this thread that has a one-click program to revert the phone back to it's stock state. I lost my apps, contacts, etc. But my phone was back up and running.
[STOCK ROM] Odin3 One-Click Downloader - xda-developers
tl;dr If you brick your phone, or you want to revert back to a clean stock ROM so AT&T doesn't know you have been playing around, use the program above to restore to factory ROM.
So using this program unrooted your phone and restored the stock firmware?! If so that's friggin great! Did u get the AT&T apps back?
Whew! Glad you got it restored....I haven't rooted my Captivate and don't think I will. Don't see enough benefits, for me personally.
I "bricked" mine too. I think SetCPU messed up my phone, and didn't want to wake up regardless if it was on or off. Ended up doing a nandroid restore (thank goodness I did one), and everything is fine. It's a little dated (3 days, but Ive done alot in those days, haha), but I'm just glad its working again.
I'll need to look into that. I know about the Clockwork Mod, but I would like a solution that will allow me to take a full backup of my phone (with contacts, apps, settings, etc) and then allow me to restore to that backup should I mess up my phone playing around with it. Do you know if Clockwork does that, or does your method allow that?
