reddragonfire
hi guy i hope you can help,
I have htc desire hd and was doing something on my phone and then suddenly nothing, it stays on the white htc screen, can access the boot screen and it says there are images missing, if i go to recovery and then try to get it to apply updat from sd card it says invalid operation, i fear i may have screwed my phone up,
When i put usb in it makes a noise as if to say it connected but thats it nothing else,
the file i have been trying to get the phone to work on is PD98IMG.zip but nothing seems to work, i have changed sd cards and nothing,
One question i did want to ak as well is when it says root of the sd card does this mean just copying file on to sd card,
I need my phone asap as going away, so any help wold be much appreciated.
Thanks in advance
Thanks in advance
