David Dubz
As it turns out I did! I just installed it from my SD card... The moment of truth... OMG OMG OMG OMG OMG THANK YOU SO FREAKING MUCH OH MY GOD YOU ARE AMAZING GOD PRAISE YOU
You're welcome! Glad I could help!
Happy Bean works amazing, too!!!Probably tomorrow I'll try Krazy Kat... Sounds amazingHappy Bean works amazing, too!!!
Origin is definitely the way to go.
Download the latest version http://androidforums.com/vital-all-things-root/841174-rom-update-origin-v2-0-4-27-14-a.html and put it on the root of your sdcard.
Boot into recovery and choose install zip > from sdcard > origin.zip > install
That's it!
thanks so muchYou guys flatter methanks so much
If you currently have Happy Bean and you want to try Krazy Kat, you can install it from cwm without wiping cache or factory resetting. Just flash it directly on top of Happy Bean. They're exactly the same besides the status bar icons and little ui changes. All your apps, texts, settings, etc won't be erased.
Although fyi when you update the ROM or change over from Happy Bean to Krazy Kat (or the other way), you have to go into the xposed and superuser apps and update their framework again.... Which is annoying. But that's the app's problems not mine. It 's not too big of a deal
I'm planning on getting Krazy Kat, but what do I need to do through Xposed? Like, what things should I do and how? And when, too? Thanks!
