Help Bricking Of Samung Tablet?
Spudster
I have heard of the risk of Android tablets/phones bricking?
So what causes them to brick? Can it brick itself? I use to have a rooted android tablet but I reinstalled the original firmware since I Was scared of the tablet bricking, The tablet is the only thing the supplies internet at home and via 3/4G.
Can rooting brick it if you only install one trusted application that only needs root access? Im unrooted now. Recently Telstra/Samsung launched The new Firmware Update ICS it was in the middle of doing the upgrade until it froze I turned of the device without no choice, For 3 minutes the device wouldn
I am certainly not an expert on rooting. I have rooted only two of my many tablets. But from long reading and experimenting maybe i can answer what I know. Makers of Tablets hide important parts of the operating system so an ordinary user can't screw everything up and make the tablet unstable. When you root a tablet, you can lose that protection. Now you can see and remove and move files that are important to the operation of the tablet. I somehow did that to one of my tablets (I don't know how it happened). But it was a soft-brick and I was able to do a system restore and saved it (But I lost all my Apps and data). I think unless you are really into new systems and will spend the time and risk, you are better off not rooting a Tablet. That's my two cents.
I rather stay unrooted to prevent bricking.
Heres another thread
androidforums.com/samsung-galaxy-tab-8-9/689700-packet-data-won-t-work-after-connecting-wifi.html
