they best way to avoid bricking is research. research. research.
dont just find a guide and follow it, find other guides also and compare the steps.
if guide a says this and guide b says that. find out why there is differing info.
make sure the software you are using is specifically for your device.
read, read, read, read, search the boards, then read some more. then when you feel your ready, just follow the steps.
