Brightness resets to 100% after reboot or power off/on?
Superorb
Whenever I reboot or turn the phone off/on the brightness always resets to 100% once the phone boots up. It does this with Xperion ROM and also when the phone was bone stock out of the box new. Ideas?
Just want to chime in and echo what you said. I noticed the same peculiar issue with one of my two MetroPCS F6 as well. Don't remember whether it was like that when new out of box, but it definitely has the issue now.
A few more issues:
1. Timeout setting not remembered and always defaulted to 2min after poweroff and restart
2. Wifi does not connect to 2.4Ghz SSID, while has no issue connecting to the counterpart 5.8Ghz, broadcasted from the same router. It says "Saved, secured".
Tried Upgrade Recovery under LG Mobile Support Tool, KDZ stock 12b rom, and Xperion & Aroma ROMs without available.
Fixed by merely repopulating the same password in the router wifi setup, not sure why it makes any difference since no other devices on the same AP has any issues.
A few more issues:
My issues were all fixed by inserting a SIMcard. Any SIMcard would do the trick. Weird issue, and frankly shouldn't exist. But it's an easy fix.
I edited the build.prop to stop it, but this was on the kitkat port.
The file is /system/build.prop and the line I edited was:
ro.lge.lcd_default_brightness=149
I changed it from 149 to 1
