Are you using the Brightness widget or the Settings, Display Brightness slider? I found that the widget left the lowest setting too bright but, when I went to the Settings, the slider was not all the way to the left. Moved it all the way and now it's dark enough for me. Of course, you probably already did that and it's still too bright so, if that's the case, ignore me! Kevin
