Accessories Brodit car holder
DCFC79
Im considering buying a brodit to use with my desire but im a little confused, ive found this on mobile fun but how does it stick to the window or would i need to buy an extra bit like this
thanks
The Brodit is just the phone holder. It needs to be screwed/glued to a car mount. Can't tell if the one in the second link would be suitable.
Brodit do car specific mounts. You can search oh their website Brodit.se.
I didn't like where their mount for the TT located so I bought one of these
[*]. It fits alongside the radio (had to pull the radio to bolt it in). I ripped apart a cheap eBay suction mount for the phone holder. Cheaper and less intrusive than a Brodit (which seem quite deep) and holds the phone just fine imho.
[*] Can't get link to work search " dash mount bracket im* " on eBay (no quotes).
I've got the Brodit and it works well. As speedycolzalez says you need a Brodit mount (which is car-specific) but they're really good as they don't require any drilling into your dash (i.e. you can remove them and they don't leave massive chunks missing).
Very happy with mine.
