Root Broken out battery charging animation fix?
Tokenpoke
Android Expert
I really would like my powered off battery charging animation to work but nothing I can think of (permission fix, file moving) works.... any ideas?
The reason the charge image doesn't show up because on the brokenout rom they were removed from the root directory. Download this chargerimages.zip - 115.92 KB and using file explorer such as ES FILE EXPLORER go to to the / directory or the main root directory of your phone and paste this chargeimage folder make sure to extract the zip and get the chargeimage folder. After you replace it reboot the phone and it will work.
