Hi!
I'm new in the forums, I own a Samsung Note N7000, which was recently been driven on by a car
Now the screen and frame is broken (I'm almost certain it's only the screen and frame since I plugged in the battery and sim and it turned on and received calls) and I was looking for a replacement, on Ebay there is an item which is called "Black Frame + LCD Screen + Touch Digitizer For Samsung Galaxy Note i9220 N7000"
and I wanted to know if this should fit.
As I understood there is a difference between I9220 and N7000, but I figured these two variants share the same screen components (LCD, Digitizer, Frame, etc...)
Sorry for my bad English and grammar, and thanks a lot in advance!
.Now the screen and frame is broken (I'm almost certain it's only the screen and frame since I plugged in the battery and sim and it turned on and received calls) and I was looking for a replacement, on Ebay there is an item which is called "Black Frame + LCD Screen + Touch Digitizer For Samsung Galaxy Note i9220 N7000"
