Help Broken screen on Droid X need info off phone
sparky07
I made a dumb mistake today and dropped my Droid X and the screen is broke. I don't see anything wrong on the outside of the screen, but when I turn it on all I see are lines. I can't make out anything on the screen. I have insurance and have already filed a claim, but I would like to get some info off the phone.
Contacts are backed up, but I would really like to get text and pix messages. Is there a way to get info off like this off the phone?
Can't you simply connect it via USB to a computer? If you are in either PC or USB mode you should be able to download your files.
Or if you have a mini usb reader or adapter...that'll work too
Sucks about the screen though :(
This. Though the tricky part maybe attempting to access the majority of files without being able to place it in "Mass Storage" mode.
Good Luck.
if you have the android SDK you can use ddms.bat to view your screen with..
I just connected it to my computer and I see 6 folders. I have opend them all and can't see any text msgs. Do I need to change the mode? Any ideas how to do that?
I don't have android SDK
The folders are: albums, dcim, download, droidsounds, handcent, and mms.
There are also 2 .dil files
Hi all, the same thing happened with my incredible and I can't get anything off of it. I connected it and it keeps asking for a disk to be inserted into the removable disk. Any help around this would be helpful
