Browser default problems
I have a problem with the default app select in the browser. When you click a link for YouTube a pop up appears saying how you would like to open the link. I accidentally checked the box for "make this defult", but when I went to clear defaults the box was grayed out. The message won't come up again. How do I get it back?
it also happens when I go to watch a video on a website. The message Isn't there anymore
Check to make sure you are looking for that clear defaults under the correct app. Alternatively download another app for videos, like Gallery ICS or Quick Pic and that will trigger the select and app and "make this default" popup again. If you dont want to keep the app you can just delete it after you used it for the purposes of getting that popup to show again.
